Security Code for D3?
By OrangeElement · Jul 22, 2007in General💬 8 posts👁️ 1,480 views
Posted Jul 22, 2007 · 19:41 UTC#1
If I disconnect my D3, will I have to enter a security code to start it back up or will it just lose the settings/presets, etc?
Posted Jul 22, 2007 · 21:32 UTC#2
Yea I don't think that there is a security code...I'm not 100%
Posted Jul 22, 2007 · 22:28 UTC#3
There is no security code.
Posted Jul 22, 2007 · 22:33 UTC#4
you didnt set a security code in the d3 when you first installed it, did ya?
Posted Jul 23, 2007 · 00:27 UTC#5
I didn't install it. It was just a thought. Wanted to make sure I had it on hand just in case it did require one.
Thanks.
Posted Jul 23, 2007 · 02:02 UTC#6
There is no factory code but you can program your own. And yes, if you disconnect the power you will have to input the code upon reconnecting it.
Posted Jul 23, 2007 · 02:03 UTC#7
How do I set a code?
Posted Jul 23, 2007 · 18:49 UTC#8
Hit MAP, MENU, SETTINGS, SYSTEM OPTIONS.
At this point you will want to touch the blake spaces at the top of the screen. These are the areas 1, 2, and 3. The blank area above the boxes with choices like LANGUAGE, KM/MILE, INSTALLATION ANGLE. They are equally spaced apart across the top of the screen. After you have touched these areas the password screen will appear. You can also refer to page 129 in the manual for this.
