Newbie needing helph with one question
By ReinySchmidt · Jul 23, 2007in AVIC-S1💬 4 posts👁️ 2,280 views
Posted Jul 23, 2007 · 20:11 UTC#1
Looking at a used AVIC-S1 and just had a quick question. On my other GPS once I was physically at a location, I could "mark" the location and enter it into the address book and label it. Can I do that with this unit, if so how?
Thanks for the help. :lol:
Posted Jul 26, 2007 · 19:44 UTC#2
38 people viewed this and not one person can answer this question?
Posted Jul 27, 2007 · 09:50 UTC#3
If I'm not mistaken you can do the following:
Click on map point and choose navigate.
Then go to the Adress Book, then press + button and choose this position from the Destination History.
I know it is not easy but it does the trick. :)
Posted Aug 03, 2007 · 23:01 UTC#4
Another possibility: If you go directly to address book, and select the "add entry" button, the device allows you enter the location using a variety of methods. Find the "select on map" button and press it. It will take you to the map showing your current location. From there click "add" and you're done.
