Thanks again for discovering the stash of ND-BT1s at Circuit City. I am sure others here are grateful for the heads-up.
Installed the unit in less than 10 minutes myself. Only one wire and it's molded to the BT receiver on one end. The other is a red plug that only fits the red connector on the back of the Z1. Don't pay to have this installed unless you have never removed the radio.
Once the passords were installed on both ends and the bluetooth turned on in the menus on both the devices, the handshake was quick. Hands-free works great, although I couldn't get the Z1 voice recognition to recognize the numbers on direct dial. No echo problems with volume set one peg beyond center on the volume menu, and the audio is terrific through a $6k sound system. :wink:
Contacts had to be loaded one at a time using the object push protocol into the Z1 card reader. The Z1 disconnected after each card (contact), so I pushed them over individually. Curious that the Motorola manual says it supports phonebook upload. Damn Verizon, if thy are responsible.
One oddity that was mentioned on HowardForums, if you lose sync the car has to be restarted to synchronize. Shoddy programming, because the software already shuts down the sync and reinitializes fine to receive multimple manual uploads of the contacts. Two lines of code to recognize the disconnect, reset the flags and loop back to the main routine.
The phone selection is buried three or four levels down in the Z1's rather clunky menu heirarchy. Pioneer did it because you are not supposed to be able to access these features while the vehicle is moving. Of course, you can use the voice recognition. But be precise, and know all of the commands.
As for the Q, there appears to be no advantage over other Verizon phones in using the Z1. At least, there is no advantage over a phone that competently executes hands-free, which is all that I've managed to accomplish with Motorola's flagship telephone.
Maybe others have had better luck. I would appreciate some input as well.
