A noob Questions on those background pictures...
By Akisan2 · Jul 26, 2007in General💬 7 posts👁️ 1,309 views
Posted Jul 26, 2007 · 06:51 UTC#1
Does those work on the z2 as well? And I've seen that you should use nero to burn the pics...correct?
Posted Jul 26, 2007 · 11:28 UTC#2
Yes and yes.
Nero is not required but it's a very good program. Just not windows, it doesn't burn disk which are compatible with anything other than windows :)
Posted Jul 26, 2007 · 14:14 UTC#3
Thank you! I'll give it a shot!
Posted Jul 29, 2007 · 15:52 UTC#4
Can anybody please tell me how to change the backgrounds in the D3? I managed to change the splash page by burning my own NAV disc, but when I pop a disc full of jpegs in the player and try to change the backgrounds through system settings, it says there is no /pictures/ folder and that i need that...so naturally i threw all the pics into 1 folder by itself, called "PICTURES", but i still get the same message. What am i doing wrong?
Thanks in advance guys
Posted Aug 10, 2007 · 22:07 UTC#5
i did the same thing and got the same responce any one have any info ?
Posted Aug 10, 2007 · 22:10 UTC#6
i posted this in another thread but i can repeat myself once.
IN THE D3 MANUAL IT STATES THAT ONLY 20 PICTURES CAN BE ON THE DISC.
also no characters but letters and numbers in the title. hopefull this helps
Posted Aug 11, 2007 · 01:35 UTC#7
thanks for the help hottwyrd, I figured it out a few days ago. Lex, if u'r still wondering...you burn a CD-R w/ two folders, one called PICTURES, and the other you can name whatever you want, nothing specifically needed. In the PICTURES folder, put the pics that you woudl like to use, and in the other one, put some extra pics to take up space...i believe you have to have at least 1.88 MB taken up total on the disc (i could be wrong though). That will get ya straight.
