I just had an AVIC-D3 installed in my 07 F150 by Circuit City (big mistake). I picked the truck up on my way out of town and at first glance everything appeared fine. My glee soon dissipated when I attempted to enter a route on the nav system. I found a majority of the nav functions and radio preset functions were grayed out. When I arrived at my hotel for the evening I opened up the dash and found they had used two aftermarket connectors. One plugs into my OEM harness and the other plugs directly into D3 power. After a number of hours of research I discovered that the Parking Brake and VSS lead are not supported on the connector that plugs into the D3 so they were never hooked up. I’ve decided the cleanest way to correct this is to continue use of the aftermarket connectors and do a bit of repining to get access to the required leads. My problem is I do not have the power harness that came with the D3 (it’s 500 miles away) and cannot get Pioneer to tell me what the pinout is (so much for service).
Would anyone happen to have the pinouts for the D3 power cable connector? Another week on the road with a partially functional until could drive me MAD.
