Does any one know where its at, and any pics???
Posted Jul 28, 2007 · 10:43 UTC#1
and will installing it interfere with my bypass?
Speed Sense white Unified Meter and A/C Amp, pin 26
The Unified Meter and A/C Amp is behind the A/C controls in the center console.
No
i mean without the VSS wire the spedo is only 2 MPH off then the actual speedometer and is already pretty accurate, will installing this wire make a huge substantial difference?
the speedo gets its reading from voltage, it has nothing to do with the speed sense. yes the nav will be more accurate with it hooked up
