Install help
By amp0804 · Jul 28, 2007in General💬 17 posts👁️ 4,261 views
Posted Jul 28, 2007 · 18:29 UTC#1
So I am installing a Jensen vm9312 head unit in a friends 2003 Audi A4...but with Audi's gay wiring ive decided to just hardwire it. What I need help with is deciding where to hook up my Constant, 12V and Ground...If anyone can help please let me know. TIA
Posted Jul 28, 2007 · 20:03 UTC#2
Blose or non blose. Oh and hardwiring bad idea. Use a harness.
Posted Jul 28, 2007 · 21:01 UTC#3
bose symphony II ....ive had all the harness none of them match up the specific wires on the stock ISO
Posted Jul 28, 2007 · 21:26 UTC#4
haha yeap
Posted Jul 28, 2007 · 21:31 UTC#5
I would honestly be glad too if someone can point me in the right direction for the actual CORRECT harness that plugs right into the stock one. I have the harness for the amp ISO already all I need is for the power block ISO
Posted Jul 29, 2007 · 03:56 UTC#6
70-1787 is what I have listed for the blose symphony in that car.
Posted Jul 29, 2007 · 04:10 UTC#7
Yeah and I had that harness connected and it doesnt work...The pins dont match up
Posted Jul 29, 2007 · 04:15 UTC#8
which pins
Posted Jul 29, 2007 · 04:21 UTC#9
12v, constant, ground
Posted Jul 29, 2007 · 04:23 UTC#10
Can you take a picture of the harness in the vehicle. Cause from what I remember of those cars, that's the harness I've used in the past.
Posted Jul 29, 2007 · 04:26 UTC#11
not at this moment car is back at the shop but hold on maybe i can find a picture
Posted Jul 29, 2007 · 04:37 UTC#12
so i cant find a picture but basically there is 2 on the stock harness one of them is a long rectangle which supplies the amped front and rear speakers then the short black one is which carries the constant, the 12v, ground, illumination
Posted Jul 29, 2007 · 04:46 UTC#13
the black plug has 2 rows of 4 pins each. May not have wire in each location, but there's 8 total holes?
Looks something like half of this plug?
http://www.installer.com/item/display_i ... it=71-1784
Posted Jul 29, 2007 · 04:51 UTC#14
yeah its half of that block with i think only 5 wires going into it
Posted Jul 29, 2007 · 04:53 UTC#15
THen that harness should work for you. Constant and accy may be backwards, but it's the right plug.
Posted Jul 29, 2007 · 05:01 UTC#16
well its not considering i had the audi one and vw one and neither worked thats why i want to just hardwire it
Posted Jul 30, 2007 · 03:18 UTC#17
just get out a meter and test for it.. its 3 wires..
