What should have come with the D3
By jdurhan · Jul 29, 2007in General💬 7 posts👁️ 1,266 views
Posted Jul 29, 2007 · 14:29 UTC#1
I had a questionable installer, I received only a empty box, my stock corvette radio and 2 dvd disks back, I discovered this after I got home.
So far I know I am missing owners manual, could some please tell me everything I should have received with my D3 such as registration info....
I read online about a stylus or something.
I am going back next week to see if he can get my chimes to work work in my 07 corvette, they all stopped, the screen wont dim with headlights thats very blinding at night and if that were not enough last night as drove to south beach, all volume for everything just stopped, no radio,ipod,sat.rad,nav nothing works. I am so totally pissed. I just want to make sure I get everything I should have when I go back. I'm sure this is a good unit I am just off to a bad start.
Thank you in advance.
Posted Jul 29, 2007 · 15:00 UTC#2
Also you might want to make sure they connected the speed sensor (VSS) Go to MAP, MENU, SETTINGS, SYSTEM, HARDWARE INFO and see if the speed sense value goes up while driving. Just put your car in reverse for a foot or two, if it does note start counting up its not connected. Take it back and insist they connect it or if you no longer feel confident in them get your money back for the install and go somewhere else.
Posted Jul 29, 2007 · 15:09 UTC#3
Thank you, I'll check it. what all did you get with yours ?
Posted Jul 30, 2007 · 07:03 UTC#4
Antenna, mounting plate for antenna, manuals, harnesses, stylus, bracket, and mounting hardware. I think thats it. You should have gotten the standard stuff you get with any head unit.
Posted Jul 30, 2007 · 19:23 UTC#5
The manual has a list of everything it should have come with
Posted Jul 30, 2007 · 20:06 UTC#6
What's Included
What’s in the Manufacturer’s Box?
Double-DIN CD/MP3/GPS navigation receiver with 6.1" touch-panel video monitor
Plastic stylus
Trim ring
GPS antenna with attached 16.25' cord
2-3/4" x 2-3/4" self-adhesive metal sheet (for mounting GPS antenna)
5 Self-adhesive clamps
Self-adhesive waterproof pad
Red plastic wire connector
Power/speaker wiring harness
A/V In/Out harness
16.25' Speed signal extension lead (pink with attached female bullet connector)
16.25' Reverse signal extension lead (purple/white wire with in-line fuse resistor and attached plastic wire splicer)
8 Pan head ISO-mount screws
8 Flat-head ISO-mount screws
Navigation Disc for AVIC-D3 (East) DVD-ROM (Version 1.0) in jewel case
Navigation Disc for AVIC-D3 (West) DVD-ROM (Version 1.0) in jewel case
Quick Start Guide
Operation Manual
Installation Manual (English/French)
Warranty sheet
"Warning" sheet concerning power connections
Product registration card
Posted Jul 31, 2007 · 12:13 UTC#7
What's Included
Plastic stylus
Trim ring
A/V In/Out harness
Quick Start Guide
Operation Manual
Warranty sheet
Thank you very much, this is what I needed.
