Set time on D3
By ScottTRD · Jul 31, 2007in Problems/Troubleshooting💬 14 posts👁️ 1,646 views
Posted Jul 31, 2007 · 16:16 UTC#1
Hey, I just install a D3 in my 07 Tacoma and have a cople of questions.
1. When I first installed it, it would not let me change the time zone to set the time. I hadn't hooked up the VSS, brake, or reverse wires yet. So, after I hooked those up it still will not let me set the time. What am I doing (or have done) wrong?
2. How do I verify the VSS is working?
3. So other than doing the hack, I have to have the parking brake on when ever I want to set waypoints and stuff of that nature. I thought as long as you were not moving you could do that without setting the bake.
Thanks in advance for any help or direction you point me.
Posted Jul 31, 2007 · 16:37 UTC#2
There is a setting that says something about 'summertime' which means daylight savings. Under that there will be a thing where you can add or subtract 3 hours from the time it is displaying. As far as I know you can't set it to the minute, just adjust the time programmed in.
Go into the settings tab in the nav menu. there should be a button for hardware info, and system info I think. will show if your VSS is connected.
in that same hardware info screen, it should always say parking brake on. If not you didn't do the bypass correctly. Can you watch movies? Do you get any error messages?
Posted Jul 31, 2007 · 17:00 UTC#3
yea the brake has to be grounded at all times for you to be able to do all the gps and watch dvds..Yea once the gps antenna is hooked up it will figure out where you are and then you can adjust the time and turn summer time hours on
Posted Jul 31, 2007 · 17:05 UTC#4
I don't think that he has done the hack. He's asking if on an unbypassed unit, will all the functions be available if the car is just stopped.
I'm not sure, but if you have everything connected correctly, I would think that you have to have your parking brake on.
Posted Jul 31, 2007 · 17:33 UTC#5
Read into the manual, it doesn't clearly say how to check the VSS. Page 69 sayd speed pulse will be zero if stationary. Which it does. When moving it still says 0. But on page 68 under 3d calibration, it shows speed pulses. That number it shows (started at 0) grows everytime I drive the truck.
Posted Jul 31, 2007 · 17:40 UTC#6
Well, I got the time set.
Posted Jul 31, 2007 · 19:29 UTC#7
What you were looking at on page 68. If that doesn't change when you move, you have your VSS hooked up incorrectly. I just tried to look quick for where it would be but I couldn't find anything.
Posted Jul 31, 2007 · 19:58 UTC#8
So under 3d calibration (pg 68 ), if the speed pulses start adding up, it is fine. I was concerned with what is on page 69. It shows the number for speed pulse to be 0. And this driving as well.
Posted Jul 31, 2007 · 20:04 UTC#9
Maybe I'm thinking of the wrong screen. I'll double check when I get out of work in a little while.
Posted Jul 31, 2007 · 20:24 UTC#10
Speed pulse should go up and you should hear a beeping with it. It will be around half of your actual speed. If it is at 0 then yes you do not have the vss hooked up correctly.
Posted Jul 31, 2007 · 20:27 UTC#11
Thanks....
Posted Jul 31, 2007 · 20:27 UTC#12
no prob
Posted Aug 01, 2007 · 14:09 UTC#13
I think I got it. I get speed pulses now. I don't here any beeps though.
Posted Aug 01, 2007 · 14:10 UTC#14
I think I got it. I get speed pulses now. I don't here any beeps though. Thanks again everybody.
