XM Status NOT CONNECTED NO SIGNAL
By BMWJ17 · Jun 30, 2006in XM/Sirius/HD Radio and Traffic Receivers💬 12 posts👁️ 4,127 views
Posted Jun 30, 2006 · 15:40 UTC#1
I have connected 2 different Pioneer XMNAV Modules to my Z1 via the IP BUS and neither of them have worked. NO I did not connnect the power lead eiether like some people have mentioned in the forums here. So anyhow this module should just be Plug and Play to the Z1 correct? I even did a Reset of the Z1 and the Sat Module itself. Is there something I am frogetting before I start the repair process for the Z1? Any help anyone could provide is greatly appreciated.
Posted Jun 30, 2006 · 23:36 UTC#2
I had the same problem with my AVIC-D1. Then when I re-read the instructions they said that if you use the module with a navi system you mustconnect the XM data cable as well. As soon as I hooked that cable up the XM Staus on the NAVI system said that XM was updating and it also showed the signal as very strong and the radio ID.
Posted Jul 01, 2006 · 01:57 UTC#3
Appreciate the input unfortunately I had the Data cable hooked up as well. So unfortunately I still think it is the Z1 IP Bus.
Posted Jul 01, 2006 · 03:34 UTC#4
This is a really stupid question as I'm sure you have it right, but you aren't hooking it up to the Ip bus out on the Z1 are you?
Posted Jul 01, 2006 · 04:15 UTC#5
No while I appreciate your attention to detail but I am connecting it to the IP bus in on the Z1 in. I have called Tundra Electronics the place I bought the Z1 and they are shippimg me RMA. So I will probably go a couple of weeks without Z1. Kind of Sux it compliments my 06 Mustang GT's dash very well...
Posted Jul 01, 2006 · 04:24 UTC#6
which xm unit are you using gexp10xmt or gexp920xm?
Posted Jul 01, 2006 · 17:02 UTC#7
I am using the gexp10xmt
Posted Jul 30, 2006 · 18:44 UTC#8
I wonder if this is a 2006 Mustang GT problem. I just had mine professionally installed except that the XM radio works great, probelm is that when I go to the information screen and XM status it reads not connected, no signal, and no radio id. Does anyone have any ideas since it is all connected properly?
Jeff
Posted Jul 30, 2006 · 19:00 UTC#9
By the way, I have the P920XM unit and not the P910XM navtraffic unit.
Jeff
Posted Aug 12, 2006 · 03:20 UTC#10
you need the other xm receiver. the one you have doesnt support xm navtraffic
Posted Aug 25, 2006 · 20:29 UTC#11
So did anyone find out how to fix it? I have the same problem in a 2006 GMC Sierra Denali. My XM radio work, but I don't think my navtraffic works at all. Speaking of, how can you tell if the navtraffic is working?
Posted Oct 17, 2006 · 02:55 UTC#12
I have the N1 and the P920XM unit. I have the not connected signal on the XM Status screen. I checked the manual and it says nothing about it.
How do I get the status information on the actual XM status screen on my N1?
