Reverse Wire Question
By bpearsal · Jul 31, 2007in Problems/Troubleshooting💬 4 posts👁️ 747 views
Posted Jul 31, 2007 · 20:24 UTC#1
I am hooking the D3 up this weekend and can i hook the Reverse wire up to the reverse lights in the rear of the car. Meaning run some wire back there and tap into the backup lights..... i have a 1999 Nissan maxima and was just looking for some guidance on this issue...
Posted Jul 31, 2007 · 20:26 UTC#2
Yea you don't have to necessarily run it all the way back there. What I would do is find the color of the wire at the reverse light bulb.. the + of course. And then find the thick set of wires running along the sides of the car underneath of the plastic panels. Find that same colored wire, strip it back a little bit and put the car into reverse and test it with a multi meter to make sure that it is the same wire. It will make it a lot easier than running a wire all the way to the rear.
Posted Jul 31, 2007 · 20:48 UTC#3
reverse wire is GREEN/WHITE (+) IN HARNESS IN DRIVERS KICKPANEL
Posted Aug 01, 2007 · 00:11 UTC#4
Thank you... This Saves me alot of work these posts are Great....
