Backup Camera Installation
By jbhorne · Aug 02, 2007in Problems/Troubleshooting💬 7 posts👁️ 1,355 views
Posted Aug 02, 2007 · 15:53 UTC#1
Just curious as to what others did. I installed my camera a year ago, but would like to know how others worked around this issue.
1) Are most of you using the Pioneer cam? or another?
2) Where did you install it? I drilled out the center of my licence plate and flush mounted it. Can't even tell it's there! (There was a big dot in the middle on AZ plates...i drilled it out)
3) On the end of the wire is a rather large 4-pin square plug (if I recall correctly). So as to not have to drill such a large hole in the vehicle to pass the wire through, did you guys cut the wire and resolder it together? or remove the plug...somehow? or just make a big hole!?
Posted Aug 02, 2007 · 20:52 UTC#2
1. some off brand I can't remember
2.Mine installed where the license plate screws go
3. Didn't have this problem
Posted Aug 02, 2007 · 20:58 UTC#3
I've done all of the above. Depends on the camera's cable and plug.
Posted Aug 02, 2007 · 21:53 UTC#4
Before I got the Z1 I had installed a camera and monitor in my Avalanche. Came as a custom packaged kit that was designed for the Avalanche. Called the "CubbyCam" since it fit perfectly into the dash. The camera is about the size of a roll of nickels and fits perfectly in the open cavity thats above the license plate on the hitch. Outstanding picture quality.
When I got the Z1 I just added a switched splitter to view on both screens.
Posted Aug 03, 2007 · 02:16 UTC#5
Using the Pioneer camera?
Posted Aug 03, 2007 · 15:36 UTC#6
D Hall that is neat
Posted Aug 04, 2007 · 20:08 UTC#7
On the Pioneer cams you can remove the pins from the plug. You should write down some notes on the wire locations for when it's time to reconnect them. You should be able to see the locking tangs of each pin though the plug. Use a very small jewelers flat head screw driver to release each pin.
