can i drive and have the camera active instead of it coming on when i;m in reverse?
Posted Aug 02, 2007 · 20:53 UTC#1
Press "Map" to pull up the map screen. Then press "Map" again to pull up the map views. Select "rear view" mode.
you could also try posting it in the right section ![]()
