So I think I'm like 90% done with the install of my D3 into a 2003 mustang GT with the Mach 460 System. Just a couple questions: I have the Metra 70-5519 harness all soldered and connected up, with the exception of a few wires- the dimmer wire (orange with black stripe), and the Amp Turn ons(Light blue wires) and negative wires(black wires). For the Amp turn ons, where should I connect them? I was thinking I could just tap the red ACC wire, but would like to check with you guys first. Also, can I just ground out the negatives then? The entire 8 Pin connector and harness part has got me all confused, any help is greatly appreciated.
Also, do I have to connect the dimmer wire to something in order to have the illumination work properly?
Thanks for any help!
