just wondering if anyone knows where to hook up the VSS wire and if there is a shorter place to hook up the reverse wire instead of going all the way to the back of the car
Posted Aug 03, 2007 · 04:46 UTC#1
Reverse Light lt. green + driver kick, harness to rear
Speed Sense dk. green/white PCM, blue plug, pin 34
Notes: The PCM is on the passenger side rear of the engine compartment.
This is the info for an 04, but it's the same stuff I used for both an 02 and an 03. so should be fine with that.
You're other option would be to pickup a metra gmos-01. Make sure it's in the black package, not the yellow. That'll give you retained accessory, vss, and reverse signals right at the radio harness.
thank you!
