N2 - External display off?
By sna77 · Aug 07, 2007in General💬 7 posts👁️ 1,123 views
Posted Aug 07, 2007 · 13:35 UTC#1
My external display on my N2 (when the unit is closed) seems to have gone dark... Can anyone think of what's wrong with it?
Posted Aug 07, 2007 · 14:10 UTC#2
sounds to me like the ribbon cable between the main unit and the display has gone bad, or the lcd module in the display unit has gone bad. :( most likely will need to be sent to pioneer for service. if you do, just send them the dash unit with no hardware, trim rings harnesses or anything, just the faceplate. depending on when you bought it (less than 12 months) and from where (an authorized dealer, not flea bay) it may be covered under warranty. if not, may be a fairly cheap fix.
Posted Aug 07, 2007 · 15:41 UTC#3
i think i can live with it off... its only an issue when the unit is closed... when its open, the LCD background works just fine....
Posted Aug 08, 2007 · 02:01 UTC#4
actually just noticed that everything is dark except the touch screen.... sound like a loose connector somewhere??? no blue lights at all...
Posted Aug 08, 2007 · 02:16 UTC#5
like the other member stated, sounds like a bad ribbon cable. being replaced free by pioneer right now.
Posted Aug 09, 2007 · 00:56 UTC#6
just send it in to pioneer and they fix for free?
how long do they have it for?
Also, what will they say when they see my soldering job on the bottom?
Posted Aug 09, 2007 · 01:07 UTC#7
They will most likely replace the circuit board if they see the bypass is done. Has happened to several members here.
As for turnaround time, I have no idea. You will have to ask them when you call Pioneer tech support to get an RMA # for the free ribbon replacement.
