I just finished installing a Z1 in my 2003 BMW 325i, and everything seemed to be running great, but I noticed that the speed calculated in the Z1 Dynamics Screen from the VSS wire was completely off. When I'm going around 20 KM/H it says 80km/h, if am just rolling it says I am going 20km/h, by the time I get to 80 km/h it tops out at 280KM/H. Now obviosuly this is adversly effecting my nav, as it is completely off since it seems to think I am driving a rocket. But the guage on my dashbaord is accurate of course.
I have tapped the VSS wire (Black/White) in 3 places, 2 seperate wires in the J-BOX behind my glovebox(why there was 2 of the same wire I don't know so I tried them both with the same results), and then I figured I'd try to tap behind the gauges directly and saw no difference, same result. Im pretty sure it's the right wire(read this in a couple different forums) as when I push the gas it goes up (even if too quickly) and when I let off the gas it drops back to zero when I stop (even if a little late since I have long stopped before it thinks I have). it does register when I am moving backwards and all the rest of the wiring is great.
I have read again and again that my vss wire is Black/White and I just don't understand why the speed is off by so much, with the VSS wire unhooked, my nav is STILL horribly out of sync and shows me driving off the side of the road, and just "snaps" into any road that's close to what it thinks I am driving along. Help please, I am lost and without a clue......
