warning prompt removal
By toobroke · Aug 07, 2007in Hacks/Mods💬 5 posts👁️ 3,160 views
Posted Aug 07, 2007 · 23:27 UTC#1
Is there a way to eliminate the Pioneer prompt that comes on every time you turn the D-3 on? It does not come on when you put your vehicle in reverse with the back-up camera until you put your vehicle in drive then you have to press ok to have the unit return to nav. I know it's not a big deal to press ok every time but it is a pain in the azz. Thanks
Posted Aug 07, 2007 · 23:48 UTC#2
No way around that mesg.
Posted Aug 07, 2007 · 23:56 UTC#3
Not even a computer geek can figure this out? Dam.
I going to have a sore finger from pressing that dam prompt all the time.
Posted Sep 07, 2007 · 00:13 UTC#4
Well I'm fairly sure it's hardwired into the unit, so it's most likely in there for good.
Posted Oct 04, 2007 · 20:01 UTC#5
If im thinking of the correct mesage, if you have a route set in the navi i beleive this message wont show up...
