back-up camera question AVIC D-3
By toobroke · Aug 07, 2007in Hacks/Mods💬 22 posts👁️ 7,893 views
Posted Aug 07, 2007 · 23:46 UTC#1
I installed a non pioneer back-up camera. The image is reversed on the screen. Does the Pioneer back-up camera also have the image in reverse and can this be changed?
Posted Aug 08, 2007 · 00:13 UTC#2
the pioneer camera also has reversed image.
Posted Aug 13, 2007 · 16:28 UTC#3
the image will always appear reveresed as the camera is pointing backwards. if the image was not reversed when viewing in a forward location things would appear to be on the wrong sides.
Posted Aug 13, 2007 · 23:27 UTC#4
Obviously you don't know much about backup cams, because there are backup cams that don't reverse the image
Posted Aug 18, 2007 · 01:57 UTC#5
What are some other back-up cameras that can be used with the D3, and how much are they?
Posted Aug 18, 2007 · 02:48 UTC#6
http://cgi.ebay.com/New-Backup-Camera-o ... dZViewItem
This is the one that I and several other members on this forum recommend. It is an excellent camera. This seller is also top notch and recommended by several forum members here.
Posted Aug 23, 2007 · 17:46 UTC#7
Why would you even want to have the picture normal? If you're using the camera for "backing up" or even just while driving and its not reversed then You will end up making a mistake (if you're relying on it). Not trying to say anyones stupid enough to do it, but why not keep it reversed so you can see EXACTLY what you need to see!
Posted Sep 10, 2007 · 04:25 UTC#8
Some people don't have the mindset to orient itself. By looking at the screen on a reversed camera, you can actually relate to your surroundings with left or right side of the vehicle while facing forward (thus looking at side mirrors and dvd screen). On the other hand, by turning your head backward towards the rear of the vehicle, like most people should when backing up is the same as the normal camera would be facing, thus, giving that image. But people can't associate the image in their mind with which way things are located at a quick glance whether an object on the screen is on the left or right side of the vehicle.
What i'm trying to establish here is people can't tell whether the object is located in conjunction with the vehicle while the head is facing forward with a normal camera. Unless you have that kind of mindset that everything is on the opposite side.
Posted Sep 10, 2007 · 11:23 UTC#9
As a curiosity. The backup camera would turn on when you put your car in reverse. But when you put it to Drive, you pass the reverse more for a fraction of a second, enough to blink your rear white lights. Does the avic turns to the backup for that fraction of a second or you need to be in reverse for 1-2 seconds before it switch?
Also, in the settings, there is a "Polarity" option. Does this reverse the image when changed?
Thx!
Posted Sep 10, 2007 · 20:20 UTC#10
My Pioneer BU Camera does not reverse the image.
And yes, when you Pass R on your way to D it flashes on the D3 Screen.
Another nice feature (after the hacks) is that you can check the BU Camera while towing something.
Posted Sep 10, 2007 · 20:45 UTC#11
It does that even when you have not performed the bypass
Posted Sep 10, 2007 · 21:26 UTC#12
what? someone hacked their d3? no way
Posted Sep 10, 2007 · 21:39 UTC#13
from the installation manual:
• This product is a rear view camera for checking
the view at the rear of a car.
A rear view camera is a camera that provides symmetrical
images in the same way as rear and side
view mirrors.
simple terms "reverse image"
Posted Nov 19, 2007 · 20:15 UTC#14
can you use the cheaper backup cams? something that like $20?
Posted Nov 19, 2007 · 20:46 UTC#15
Sure, but don't expect the picture quality to be as good, or last as long as the better ones
Posted Dec 02, 2007 · 18:16 UTC#16
I bought my Avic-d3 from crutchfield and it came with a free BOYO VTL400 camera with a CCD sensor not crappy CMOS.
If you're going to use the camera for rear view, you need the camera to be REVERSE IMAGE if not is not worth it. and please buy CCD sensor cameras not CMOS.
Great resolution during the night and day.
Posted Dec 03, 2007 · 00:49 UTC#17
i recommend using the audiovox rear view camera... you could reverse the image at the pull off a pin and it also has left audio... they also make a license plate frame one, but that one is flimsy and fragile... ill post pics later...
Posted Jan 07, 2008 · 16:45 UTC#18
I have the pioneer backup cam, and the images are not reversed. If looking strait ahead at the monitor (D3), the objects are on their respected sides. For example, an object on the drivers side is on the left hand side of the monitor
Posted Jan 07, 2008 · 17:16 UTC#19
Doesn't that make it reversed?
Posted Jan 07, 2008 · 18:52 UTC#20
yes, i guess it does. I thought the confusion with the other posts was that the image was reversed on the monitor...making for confusion while looking at the monitor.
Posted Mar 14, 2008 · 22:29 UTC#21
so a hack has to be performed for the back up cam???
Posted Mar 14, 2008 · 23:15 UTC#22
No, the navigation has a back-up camera input on the white harness
