Happened once in a while with my old razr, but everytime the iphone picks up a call it makes a pop over the speakers. Other than that calls come through fine no echo, etc. The pop is just annoying. Any ideas?
Z1 pops when my iPhone picks up?
i had that problem for a long time
had my Z1 swaped for Z2 and still doing it ![]()
do you have a system AMP subs please post ur setup
phone is too close to your unit..........
not even i pick up calls out side of the car and still get it
HMMM...........Your bluetooth module is too close to unit
My bluetooth is directly under my unit, sandwiched in between the avic and the xm tuner and I've have no issues with noises/popping sounds when using my phone.
And not eveverybody does. Mine is also close to my unit and i have no issues either. But i have seen a few times where some phones it causes a problem if the module is too close. I have a nextel i605
yaa my BT is rite on top of the unit
i think i will move it in the morning
Yah I have two amps one for the doors and one for the sub. The blue tooth unit is far enough away from the stereo I beleive. I have a STi and the bluetooth unit is prob about two - three feet away, almost under my glove box. Like I said only happend once in a blue moon with my razr but happens every single time the z1 picks up a call through my iPhone. Only happens on pick up though. Never happens during the call. Could the bluetooth module be bad?
well i have the same setup as you lol 2 amps subs the works ![]()
any ways had my unit replaced that never did nothing then after some time i had my BT replaced still doing same crap
so im like %100 sure its the system
but it getts better cuz you have the same problem
so now i know its the Avic
only thing i was told its a bad ground and its sendind a charge back to the unit
so if you have more to add to this please do
your picking up interference from somewhere. either powerwires, rca's....and an eletronic field is being created..try taking bt unit out and putting up high away from everything and then test it.
yaaa im doing that today
maybe stick it in my head liner
I will try moving mine also this weekend and let you guys know what happens
please do
OKay I couldn't wait and thankfully my module is right under my glove box so all I had to do was stick my head underneath and pull it off. The cable was neatly wound up and zip tied so cut them and extended the cable to the point where the module was sitting almost in the back seat. Used my house line to call my cell, pop on pick up again. GRRR. Only think I can think of the bluetooth module's wire is running somewhat close to my zapco signal amplifers they adjust the voltage to give a cleaner speaker signal to the amps. However the cable is a few inches away and moving it will require a little more work. That I will try this weekend. Ugh. Maybe the module is bad or its just the phone?
well its not the modual don't forget i had all my stuff replced by the nice ppl @ pioneer
and all my wires are away from my BT so wait untill i move mine over and i will let you know how that works
and i don't think its ur phone
i had a
Razr V3
Krazr
sony W810
Samsung D606
HTC tytn
and they all do the same thing
Hmm, my reg razr worked fine for the most part. I will wait for your findings before I go nuts moving stuff around =).
