Just Installed A Modded D3 In my 2003 Montero Limited.I had to move the HVAC controls to the Bottom so The double Din radio can fit.
looks good man! what i do to fill in gaps (at least to look filled in) is use black tape back behind the dash it doesnt need to be flush with the dash just cover up all the tan or light colord objects back there
anyways nice!@
anyways nice!@
Good TIP. I broke the plastic ring that goes around the radio.It has to be modified a little to fit. I'm going to try the black tape tip first to see how it comes out. Thanks.
i dont think u need a trim ring for that little of a gap
the trim that comes with the d3 is retarded!!!! y couldnt they make the opening 1/4 inch smaller so it actually fits the d3 with out gaps. and make it out of the same gloss black plastic that the d3 is in...
sorry i got off track there
neways nice install n have fun with ur new avic
If the d3 trim ring would have worked for you, I have 8 of them sitting in my tool box. I'd be more than happy to drop one in the mail for ya. Just pm me your addy. If not, then best of luck and enjoy.
cntry have u ever used the d3 trim on any other avics? does it fit d2 or z's?
i really wann know wtf pioneer was thinking
I don't beleive so. I have used it with a jensen double din that I put into a stealth a couple days ago. Well that and the eclipse condom too.
Thanks for the offer. I'm going to try some Black Tape. Does anybody know were the VSS wire is for the 03 Montero?
Speed Sense white/blue cluster or center message display
Notes: Also found in the radio harness on some models.
Speed Sense white/blue cluster or center message displayNotes: Also found in the radio harness on some models.
Good Looking.Thanks for all the info.
