what gauge wire is the extra vss wire they give u?
By raddd · Jul 01, 2006in General💬 4 posts👁️ 907 views
Posted Jul 01, 2006 · 22:30 UTC#1
k i went to have my z1 installed at a stereo shop and they installed it but not to wat we agreed on...so an arguement broke out and a complaint was filed on them with the bbb....so anyways i need a new vss wire so it can reach my gauge cluster so i was wonderin if i can use reg wire to extend the lenth?
Posted Jul 01, 2006 · 22:45 UTC#2
Sure can! You should probably try to match the same relative size though.
Posted Jul 01, 2006 · 22:52 UTC#3
The gauge looks to be either 16 or 18.
Any wire should do, there is minimal current on the wire.
-Jef
Posted Jul 02, 2006 · 13:44 UTC#4
Just make sure you get copper wire and not aluminum. Some of the cheap stuff you see at "bargain" locations can be aluminum.
there is no current to speak of that flows through the VSS. 18 gauge wire should be more than sufficient.
