microphone
By 06SaleenX · Jul 02, 2006in Problems/Troubleshooting💬 6 posts👁️ 1,540 views
Posted Jul 02, 2006 · 02:13 UTC#1
i had my microphone flush mounted into the overhead light console
when i make calls everyone says it sounds muffled
is it possible that the microphone has to be dropd out moreso and not Flush mount?
thanks
Posted Jul 03, 2006 · 06:41 UTC#2
Yes, its a noise cancelling mic so you shouldn't flush mount it
thanks
Posted Jul 04, 2006 · 00:13 UTC#3
The Z1 mike appears to be omnidirectional. Have to wonder whether an A-pillar mounted unidirectional mike might solve the problem once the audio is moved to the right side of the vehicle.
Posted Jul 04, 2006 · 01:13 UTC#4
thanks for the tips
had them pull the mic out and now its clear an non muffled :)
Posted Aug 02, 2006 · 03:48 UTC#5
What solves the echo problem? My callers all complain about an echo, I'm only at three bars on my volume. The mic and/or the voice cancellation algorithm in the software are faulty.
Posted Aug 02, 2006 · 15:11 UTC#6
Nothing really "solves" it at this time. I have my volume turned down, the mic next to the driver's A pillar, and the audio playing out of the right speaker only. I have no echo. But you have to listen carefully because my volume is low (about 3 bars if I recall)
