Anyone know where I can find this trim kit for my 02 Audi A4? Could it be a custom fab. perhaps? Let me know if anyone here has an idea. Thanks again.
BUMP! can anyone help me out here?
Not Sure but you may be able to use the AU2390B. It has a pocket that you can probably remove and cut the center bar out and make it flush. Also not sure what color your dash is or what kind of finish you have but this may be a start.
PS, made by Scosche
I never liked how the double-din kits for B6 A4's had to have that inside bezel. It's like 2 seperate pieces.
Hrmm
metra makes one.99-9101 or 99-9102 cant remember but its one of those.
i'm actually looking for the bezeled look. i don't want the deck to sit flush into the kit. so far you guys have gave me the metra kit and the scosche one. is anyone out there certain of which DIN kit it is? i want to get this install done asap but i don't want to be stuck with the wrong parts. thanks again for the help guys
if you want the look of the first kit, get the metra. you will have to get the mounting sleeve/trim ring from pioneer tho as the new units dont ship with that.
Hey what's up. I have an a4 too.
Here is what you need:
Metra 99-9102
Pioneer ADT-VA133
That should get you setup like the first picture. Make sure the Metra is the double din one, it will have a bar in the center that you will have to cut out. It's not the one with the pocket at the bottom. Let me know if you need anything else.
thanks guys. i'm doing the install later this week. pics coming soon!
Good luck. Oh and supposedly you put the dash kit in first and then the metal cage for the Avic. I coudln't get this to work and ended up messing up my dash kit. ![]()
Metra 99-9102
Pioneer ADT-VA133
Do you need the ADT-VA133 if all you need is that plastic ring so it fits in to the Metra?
Metra 99-9102
Pioneer ADT-VA133
Yes you need it, it secures the Pioneer to the dash. If not it just sits in the dash opening. I drove around like that for a week, not cool.
Metra 99-9102
Pioneer ADT-VA133
Well I dont know exactly.... I have custom brackets for my Z1. It's secured and installed already. I have a custom face plate, which I think I want to ditch. If the Metra kit would fit perfectly around the Z1 I would be fine as I am sure I could find way to secure the bezel. But it seems I need that extra plastic piece to make it fit all flush.
Metra 99-9102
Pioneer ADT-VA133
Oh! Sorry, I thought you were the original poster. I didn't realize you had a Z3. In that case you don't need that ADT-VA133 kit, but that's the only way to get that trim piece. I guess you could call Pioneer and ask them if you can get it some how.
hrmm, i did this install this week, it looks good but not as good as the top pic does, problem i have is my trim ring sticks out from the dash, its not all tucked in like on the picture, its like you would need to get the cage to sit further into the dash but its in as far as it will go, anyone have any clue what this guy may have done to make that work? he also somehow utilized the chrome lower trim piece from the factory stereo it looks like
I saw that too. I think he cut part of one of the trim pieces so that the smaller piece could sit farther back in the larger piece. Were you able to get the outer trim piece to fit without breaking off the tabs?
yep didnt break anything, only cut out the center bar in the kit using a hacksaw blade, it looks good dont get me wrong, just whoevers that is looks better, i think maybe its a diffrent dash kit, because that chrome trim on the bottom is part of the factory stereo itself. i would like to know who's car that is so i can ask some questions on that.
Let me know if you find out. I think he's on Audizine.com. Try a search if you want.
Yeah the guy with the B6 with the D3 installed, I took that picture off of AZ. dumptyhumpty I'm pretty sure you're name looks familiar around AZ (I post under the same name - has6) I got the install done like last month but I never got the middle trim piece to fit flush, it's so goddamn frustrating because I'm sort of OCD and it looks nasty riding around with no trim piece. I like how he incorporated the OEM metal bezel on the D3 but first things first, I want to know if there is another way I can get my hands on that little trim piece again. Let me see how your D3's look on a B6 (i'll get my pics in soon as well) Thanks guys!
Yeah I think i've seen you around. I'm one of the guys with the Supercharged 3.0s.
Right now I don't have any trim pieces on my d3. I ended up breaking the bigger trim piece and i'm going to reorder it soon. This time i'll be a little more careful. When I get it all cleaned up i'll post some pictures.
