I have installed the AVIC Z2 into my truck. The only wires I have left to connect are the illumination signal source and vehicle speed sensor (VSS). I did manage the reverse signal.
I have a 2006 Chevy 2500 HD diesel with Allison transmission (crew cab).
I have tried the illumination wire behind the light switch (brown/white wire and purple wire) with no luck. I have also tried the VSS wire behind the instrument cluster green/white wire with no luck.
Any help on wire location would be appreciated.
BTW, my Z2 did not start-up beyond the splash screen for the first time (it is very hot this week). I contacted Pioneer and they are aware of the problem, but really don't have any fixes (the Pioneer guy said it happens even in 60 degree weather so it may not be the heat). Pioneer is supposed to give me a response back within 24 hours as to the problem. Yeah right...
