N2 not powering on
By dodgeintrenton · Aug 09, 2007in Problems/Troubleshooting💬 17 posts👁️ 2,997 views
Posted Aug 09, 2007 · 20:49 UTC#1
It all started a few weeks ago when my n2 began turning on and off randomly. I believed that it had to do with me leaving the face attached on a hot day. Since then I have removed it and stored it in a cooler place. It had a few problems since but nothing major. Today it worked fine all morning. I forgot to remove it again and now it will not turn on at all. I also had a problem with my alarm today which drained my battery which necessatated a jump. Could all of these problems be related? I checked the fuse, the wiring , and now I'm pissed. I need to use the unit next week to drive down south. It figures, the one time I could justify buying it to the wife, It breaks down. Thanks for any input.
Posted Aug 09, 2007 · 21:01 UTC#2
year make model of the vehicle would be helpful
Posted Aug 09, 2007 · 21:49 UTC#3
01 Durango slt 4x4 4.7L I also just noticed that the red blinking security light is not blinking at all ..At least I know that the face alone is not the problem
Posted Aug 09, 2007 · 23:02 UTC#4
If the blinky light isn't blinking, then odds are pretty good you got a blowed fuse in the vehicle. Check ALL of them, and let us know.
Posted Aug 09, 2007 · 23:56 UTC#5
just out of curiosity do you have any idea as to what fuse could be effecting the radio's power if not the radio fuse itself. Is there a larger fuse that handles a group? I know it is definitely not the radio fuse, i replaced it with a brand new one(twice to make sure i didnt have duds). I will check the others in a little while(when my son passes out). I know that my alarm problem caused the ignition to turn on and off repeatedly for who knows how long today at least a half hour, could it have shorted out from the rapid on/off cycle? I'll get back to you . Thanks
Posted Aug 10, 2007 · 02:31 UTC#6
I checked the fuses and all are in working order. I pulled unit out and checked voltage on yellow and black wires running into black box got around 5volts if i remember correctly. If it was a fuse I would get 0 right? I don't know what to do. It was so sudden. Are there any tests I can run that may diagnose this issue? The nearest pioneer repair spot is about 15 miles away, but the guy seems like a dousche. He gave me an attitude when I called about the thing turning on and off on its own. I buried my wires like a pro, and he wants me to dig them all out which I won't do unless its completely necessary. I need help Losing my head.
Posted Aug 10, 2007 · 03:23 UTC#7
Bro if you used a volt meter, on DC volt checking, and your black and yellow wire read 5 volts!! you got a battery problem PD. the voltage is WAY LOW in your truck.
If you have you meter on OHM's then 5 OHM's for a fuse is fine, thats normal resistance in the meter leads.
5 Volts, = BIG problem in little durango Ville
Sounds like a battery, or alternator, Poss the both! bad voltage regulator, Hot days you turn on A/c and use evrything else at once, Hotter the wire, the harder for electrons to flow, more resistance = BIG PROBLEM..If voltage regulator...
You need MECH help
Posted Aug 10, 2007 · 13:32 UTC#8
This morning I pulled it out again and tested it . the 12v.ignition(red wire)is getting 13.5volts. The 12v. constant is getting 5.1v (yellow wire). does this mean the unit is a having issues? COuld it be the brain? I'm at a loss. All of the other electronics in the vehicle are fully functional. The battery is reading 13.5 volts. Why is it just the nav thats messed up. Could it be the on off beat down it caught yesterday during my alarm mishap?
Posted Aug 10, 2007 · 14:16 UTC#9
A severely corroded fuse could be your problem too. I've seen that happen on a couple occasions where the legs of a fuse were coroded to the point the voltage would drop.
and 5 ohms resistance is not normal for meter probes. A good set of probes should meter less an an ohm of resistance.
Another thing to do is to hook the power probe up to the constant wire and ground the negative probe to the battery. If you're still reading 5 volts then it's a fuse problem. If you read 12 volts or more, then you have a bad ground. Which could also cause your problem.
Posted Aug 11, 2007 · 00:15 UTC#10
Well I was running the suggested tests and heres what happened. My battery was shot it died and wouldnt start the car. I proceeded to buy new. I cleaned up all of my connections under the hood. Double checked all of the fuses. Once that was out of the way I volt tested those wires again the red 12v ignition is still perfect at 12.5v and 13.5 when running. The yellow constant is showing 5.0v and then it starts slowly elevating. what could cause this? At one point it got up to 12.5 so I attempted to hook up the n2 and it wouldn't turn on . I checked the voltage and it was back at 5v and rising. is it a bad line or what. I can't figure it out .
Posted Aug 11, 2007 · 00:20 UTC#11
When you say you checked all of the fuses, did you remove them and look at each one.
Posted Aug 11, 2007 · 01:36 UTC#12
I checked the continuity of all the small automotive fuses in the small block in car and big block under hood with a multimeter set for ohms. I physically removed and checked a few. I checked the radio one a multitude of times replacing it at least 4 times to be sure. Others that had inconsistant read outs were checked, replaced and checked again. I'm wondering if during the melee of my alarm issue if when i was grabbing for the valet button under the dash i might have somehow effected that wire in its path to the back of the n2. If it is a big fuse I dont know how to check them or how to find out which one may have a bearing on this issue. Any ideas?
Posted Aug 11, 2007 · 01:43 UTC#13
One of those big fuses you mention would cause a lot more than the radio to not work. The only other option I can say would be to run a new line from either the ignition harness or the battery to the avic.
Posted Aug 11, 2007 · 02:13 UTC#14
Tomorrow I'm going to run a new line what size fuse should i put inline. Thanks for the input. I'll let you know how it works out, hopefully it will clear up the issue.
Posted Aug 11, 2007 · 02:16 UTC#15
Depends on the gauge of wire you're going to run.
18 gauge 10amp
16 gauge 15amp
14 gauge 20amp
12 gauge 30amp
If I were doing it, I'd run 14 or 12, this way you have plenty of availible room for any addons you might want. XM, sirius, ipod, etc etc.
Posted Aug 11, 2007 · 05:32 UTC#16
Yea you should have just ran a new mem wire right when you saw 5 volts. The wire probably has a short in the wire somewhere or it got burned up somewhere, just leave the bastard and put your new one on and you'll have navi back up in a second.
Posted Aug 12, 2007 · 15:01 UTC#17
Yeh I should have. Well I did and it worked. I ran a new line and fused it the n2 powered up no problem and is running great. I appreciate all of your help. This forum is a great thing, you can't get help like this from any manufacturer's customer service. I have one quick question thats unrelated. If the XM and sirius merger goes through will I be able to get the navtraffic without getting a whole bunch of xm equipment. I already have sirius and don't want to switch(howard stern). If not is the n2 capable of using sirius's version of the nav traffic. Also what's the word in the industry on the sirius mobile video? If this topic isn't allowed in this forum let me know and I'll start a new post in another section. Thanks again you guys saved my trip down south. I would have had mapquest printouts all over the place.
