it's not under the glovebox. On the passenger side of the car you'll see a plastic piece that runs the length of the door opening. Pop that up. You should then see a bundle of wires that runs from the front of the car to the back. If you don' see that bundle, then move the carpet, it might be under the carpet.
You mean the passenger scuff plate? That is the plastic piece along the passenger door. I removed that before to run the wire for backup camera. There is no wire there. I install amp and there is no wire under carpet.
I may not say it clear but when I say glove box I meant: remove glove box and right below it you see the fuse box. All wires will come from firewall and end up here. I check for J05 which is on the back side of fuse box and look for wire green/black. It's not there.
