Alright, first time ever taking apart the dash and removing the radio. WOW that was pretty damn simple, and I don't know why the heck they had to leave pry marks since I didnt have to pry anything at all... They probably don't have experience taking apart the 07 pilot I believe. Now I'm pissed.. But I have it all taken apart inside my car outside and I need some questions answered, please.
Well a couple observations first:
The connector was plugged in the INPUT of XM radio unit so I took it and plugged it into the OUTPUT as I was told to do. Won't know if this works until I put everything back together.
Now the bypass... I saw that the light green wire was grounded, good. Now. for the 2nd wire, the isntaller just took a random foreign wire, cut both the ends, grounded one end and stuffed the other into the socket in Ducati's "2 wire" instruction picture. I moved the connector a bit and the wire just fell out.. Don't think it was in there too good obviously...
So the yellow wire from "connector 1" on the bottom left set of wires (in the black plastic block connector) has a fuse on it right? I just want to make sure its the right one before I take it out of the connector.. It goes through a black plastic piece that has a fuse in it, then its spliced to 3 other yellow wires... at which point do I take the yellow wire and ground it? Should I ground it including the fuse? And what are the 3 other yellow wires spliced to it?
Also, for the VSS. The ahole told me he connected it, but it got some electrical tape on the end and its not connected. What a jerk.. This one seems like a tough one because I don't have the slightest clue how to wire it behind or through the firewall and such so I might just have to have the slightly less clueless installer try to do it.
Thanks for the help so far
