z2 bypass trouble
By mrdsl2217 · Aug 10, 2007in Problems/Troubleshooting💬 6 posts👁️ 986 views
Posted Aug 10, 2007 · 14:21 UTC#1
this is my first post so please dont be to harsh. ever since i installed the update cd for the z2 bypass my radio has sounded terrible almost as if the amplified antenna is not on. i thought the problem would be fixed after i had the 2 wire portion of the bypass done but nothing the radio still sounds bad. i remember before i did the update the radio worked and sounded fantastic has the update caused this or is it possible for the amplified antenna to come loose? please help thanks
Posted Aug 10, 2007 · 20:13 UTC#2
You hooked up the wrong blue wire when you installed it. Go into the initial/setup menu and change the antenna control setting to the other one
Posted Aug 10, 2007 · 20:27 UTC#3
i dont know how that could have happened since i had a professional install and the radio sounded great before i put that bypass cd in and did the update
Posted Aug 10, 2007 · 21:13 UTC#4
do what whtcrxghst said. The system probably reset when the update was put in. Which would have changed the setting that he's speaking of. BTW what kind of vehicle is it you speak of.
Posted Aug 11, 2007 · 00:28 UTC#5
I love the liberal use of the term "Professional" in the electronics industry. So few actually know what they are doing
Posted Aug 11, 2007 · 01:07 UTC#6
I'm a professional pain in the ass :D
