HELP rear camera very blurry
By sha · Aug 10, 2007in Problems/Troubleshooting💬 14 posts👁️ 3,276 views
Posted Aug 10, 2007 · 17:05 UTC#1
I have the D3 with the pioneer rear camera and sometimes it blurry and sometimes it works just fine. Check out the pics so you can see what I mean. Does anyone know what I should do or can do to fix this problem?
click on photo
Posted Aug 10, 2007 · 18:47 UTC#2
First things first, check and make sure the ground sheild of the plug isn't hutting anything metal in the dash. Next up check the cable for any obvious kinks. Finally where's the box for the camera mounted. Looks like that box might have gotten wet.
Posted Aug 10, 2007 · 23:55 UTC#3
or try cleaning the camera :lol: lens
Posted Aug 13, 2007 · 13:15 UTC#4
I dont know where anything was mounted because I didnt install it so I am going to have to do some digging and trace it all out I guess. The wierdest part about it is it only does it sometimes. Like this morning it is fine.
Posted Aug 13, 2007 · 14:38 UTC#5
dammnn that sucks..I got a 30 dollar one off ebay and it doesnt do that!
Posted Aug 15, 2007 · 13:37 UTC#6
^^thanks^^
Posted Aug 15, 2007 · 13:38 UTC#7
does anyone else have any insight on what might be wrong?
Posted Aug 21, 2007 · 15:50 UTC#8
anyone?
Posted Aug 21, 2007 · 17:53 UTC#9
it doesnt look blurry to me. It looks like it is some sort of static or interference. What kind of camera did you buy? Are the wires that came with it properly insulated? Where did you tap into for power? Perhaps you just got a bum camera. Just a few ideas.
Posted Aug 21, 2007 · 18:34 UTC#10
I would go back to your installers ... something wrong there. If it is intermittant, then my first guess would be a loose wire or a short of some kind.
Posted Aug 24, 2007 · 17:08 UTC#11
it is a pioneer camera and the problem is I live in Va and it was installed in new jersey. I will check for loose wire the problem is I have do Idea where anything was installed
Posted Aug 31, 2007 · 17:18 UTC#12
Have you had the problem fixed yet? Interested to hear about it.
Posted Aug 31, 2007 · 17:56 UTC#13
Mine looked just like that and after several hours the installer located a pin in the rear view cable that goes into the back of the head unit had pushed out a little bit. He pushed the wire back in and it now works fine. He located it by having the rear view camera on and reaching behind the head unit wiggling the wires. Thats why sometimes it would work depending on the bump I would hit would cause the wire to make contact.
Posted Jun 19, 2008 · 04:04 UTC#14
I have been reading these post trying to fix this problem. I had the same problem as sha. It turned out to be the same problem as lee roberts, a black wire going into the head unit was completely loose, after reading this post wasnt very hard to find, fixing i however was. it is something like a 24 gauge standed wire, and putting it back in the connector was no easy task. but I got it back in there, problem solved thanks guys.
