Another bypass question
By vfr800rider · Aug 15, 2007in Problems/Troubleshooting💬 2 posts👁️ 725 views
Posted Aug 15, 2007 · 13:59 UTC#1
Its clear that you ground the parking brake. I also understand that you move the mute wire. What do you do with the mute wire after you move it? Do you ground that as well. Thanks in advance for your help.
Posted Aug 15, 2007 · 14:29 UTC#2
Yes move the mute wire and then ground it as well as the parking break. All the info is here, just take a look around.
Good Luck.
