PARK BRAKE WITHOUT A SWITCH
By capricefrk013 ยท Aug 15, 2007in General๐Ÿ’ฌ 1 posts๐Ÿ‘๏ธ 1,273 views
Posted Aug 15, 2007 ยท 15:25 UTC#1
Im new here but I have been searching on here for awhile now and decided to register. I dont know if anyone has posted it before cause I cant find it doing a search but on the flipouts when you would normaly need a switch for the park brake wire I found an easy way fo getting around the need for a switch. Do a relay off the remote turn on wire to pulse the park brake wire. Pin 85 to the remote line, Pin 86 & 87 ground, and pin 30 to the park brake wire. What will happen is the wire will see nothing when the radio turns on for a split second and then when the remote line has power it will show ground on the brake wire and the unit will allow you to watch video after touching the ok button on the screen and your done. Hope this helps out alot of people who dont want to use a switch.
