AVIC D2 Navigation Problem
By hondasi15 · Aug 17, 2007in Problems/Troubleshooting💬 12 posts👁️ 1,745 views
Posted Aug 17, 2007 · 05:13 UTC#1
Hey everyone I am new to this Forum and I have a question that I hope some one can please answer for me. I installed today an AVIC D2 in my car, I setup everything perfectly to my knowledge. When I started up the unit, I inserted the DVD-Rom disk for the east coast. It did some sort of installation, and then when it was finished, the map on my screen, had the arrow indicator positioned somewhere in New York. The problem is I live in Miami FL. I figured it was some sort of default setting that these systems have, but I have been working non-stop trying to get it to work in Miami but it won't. I got as far as changing the location to Miami using one of the options on the menu, but when I input a route, the unit doesn't seem to respond properly. The Arrow stays put in the location I manually selected, and I receive no voice guidance, or any sort of directions. Can some one please help me? I am very frustrated and I'm hoping some one here can help. Thanks
Posted Aug 17, 2007 · 05:32 UTC#2
Is the antenna plugged in, and is it getting reception from the sats?
Posted Aug 17, 2007 · 13:21 UTC#3
yeah it has an "ok" signal strength
Posted Aug 17, 2007 · 19:26 UTC#4
OK just means its plugged in. How many sats are you picking up? And where is the antenna mounted?
Posted Sep 23, 2007 · 22:57 UTC#5
im having the same problem. it says ok but the satelites arent lighting up?
Posted Sep 24, 2007 · 00:27 UTC#6
Where is the antenna mounted?
Posted Sep 24, 2007 · 01:49 UTC#7
onthe dash where it meets the windshield... when i had it set up before with the non navtraffic xm reciever however it worked perfectly
Posted Sep 24, 2007 · 01:52 UTC#8
Is the antenna on something metal?
Posted Sep 24, 2007 · 02:11 UTC#9
nope, just the plastic dash
Posted Sep 24, 2007 · 02:12 UTC#10
Do you have the metal base that came with the unit. You probably need to mount it on that.
Posted Sep 24, 2007 · 04:14 UTC#11
that i do not have, anybody know where i can buy one?
Posted Sep 24, 2007 · 04:57 UTC#12
No. But just for testing purposes, just take something metal out to your car and stick the antenna to that on your dash and see if your reception improves
