2004 Honda Civic EX.... HELPPPP
By em2avicd2 · Aug 17, 2007in Vehicle Specific Wiring💬 2 posts👁️ 739 views
Posted Aug 17, 2007 · 20:50 UTC#1
Edit....I have searched this but everyone is referring to VSS.... Does the PINK wire connect to the VSS??? <--- Primary Question
im at work and got bored so i decided to go ahead and wire up the wiring harness. I read the install instructions and it seems pretty easy. There are 2 or 3 wires that I am a little confused about.
The Pink (Car Speed Signal Input) connects the the VSS wire correct??? Which is Blue/White. VSS is also known as the Speed Pulse wire or Speed Detection Circuit???
This can be found at the Cruise Control module??? anywhere else???
Posted Aug 18, 2007 · 01:21 UTC#2
Speed Sense white/green or blue/white ECM/PCM, pin A18 or E25
The ECM/PCM is behind the glove box.
If equipped with cruise control, the vss wire is also blue/white at the cruise control unit to the left of the steering column on the sedans, or the cruise control actuator under the hood on the coupes.
