VSS Wire on a '03 BMW Z4
By dave · Aug 17, 2007in Problems/Troubleshooting💬 4 posts👁️ 1,310 views
Posted Aug 17, 2007 · 23:08 UTC#1
I have a 03 BMW Z4 and can not find the VSS wire. Anyone know where to find this wire?
Dave
Posted Aug 20, 2007 · 03:42 UTC#2
This is what I found for your car. hope this helps.
Speed Sense yellow/green ABS mod, pin 10 or cluster, pin 6
Note: BMW, Z4, 2003, Speed Sense
The ABS module is in the rear driver side of the engine compartment.
Posted Oct 08, 2007 · 19:10 UTC#3
I see that there is a black/white wire in the radio harness that adjusts the radio volume due to speed. I connected to this wire and did not get a speed pulse. Could this be a positive pulse and the nav wants to see a negative pulse? I would prefer to not tap into the ABS system if possible. I keep thinking that there should be one there in case you got the factory nav.
P.S. I moved this nav from a Camry that had the speed pulse wire connected and the accuracy was much better. It will now show my position in the BMW a block or even two away from where I am.
Thanks Again
Dave
Posted Jan 09, 2008 · 22:38 UTC#4
The black/white wire will not work, thats part of the CAN BUS and is not compatible with an aftermarket unit like the Avics.
I just finished an install and can confirm this is correct. On my 2005 Z4, I got the speed pulse wire at Pin 6 in the cluster harness, a yellow / green-stripe wire. It produces 1 pulse for every .5 MPH, forward or backward, and is extremely accurate. My N4 entered 3D Hybrid mode after about 3 minutes of driving and the Avic gauges are now more 'realtime' accurate than my speedo! Love it.
BMW uses universal wiring (why don't more companies?) so this information should be the same for all Z4 (E85 & E86) models. Enjoy!
