can you bypass eclipse avn52D or any eclipse gps unit.
How is this done?
thanks to anyone who can answer this!
How is this done?
just ground the parking brake.
NOW STOP YELLING!
ahaha.. thank you very much.. i figured large letters would get attention (and it did)
so do i use work wire taps?
use anything that will ground the parking brake. what i would do it strip a portion of the parking brake wire from the eclipse nav and tie it into the ground for the eclipse nav. use solder, wire taps, its all good. most people prefer solder and heat shrink.
thanks ... what about if i want to use a backup camera. is their anything else i have to ground?
i dont remember how the rear cam looks for eclipse i believe it just plugs into the unit, if not you might need switched 12 volts, ground, and reverse input for the cam to work when you go in reverse.
You'll have to use the eclipse camera. It's a proprietary plug that plugs into the back of the unit. The unit then provides power to the camera.
I have a 2007 silverado 1500 and I grounded the parking wire, but when I am moving the parking brake light is on and it beeps....Any ideas on resolving this...Thanks
you cant have it connected to the parking brake and grounded. if it was already connected to the parking brake, disconnect it , then ground it
will try it tonight....Thanks
