Does anybody know where I can find the VSS wire on a 2002 Acura MDX, gonna be installing D3 this weekend. Also Is the tachometer wire different from the speed sensing wire, Thanks in advance guys.
Posted Aug 18, 2007 · 03:59 UTC#1
Speed Sense blue/white under passenger seat, 8 pin plug
and yes the tach wire is different from the speed sense, it shows RPM's not Vehicle Speed. hope this helps
Thank you for fast answer, can't wait to have this baby going. ![]()
I searched and didn't find 2005 Rav4 and didn't see it on the external link posted in another thread. I could use VSS and reverse signal, please.
Speed Sense purple/white back of fuse box, 28 pin plg, pin 26
Note: TOYOTA, RAV4, 2005, Speed Sense
Can also find the wire at the ECM behind the glove box, second plug from the bottom, pin 17.
Reverse Light red/blue + fuse box, 28 pin plug, pin 27
hope this helps.
Thanks Chris. That was very fast. ![]()
no problem.
