avic d3 sucking power
By bizkit · Aug 18, 2007in Problems/Troubleshooting💬 8 posts👁️ 1,104 views
Posted Aug 18, 2007 · 21:05 UTC#1
I have a 2004 chevy tahoe that I drive maybe once a week. If I go 10 to 14 days without driving it, my battery barely starts the truck. I have a new battery. I was wondering if this was common since the radio keeps up with internal memory. I did not have this problem with the factory radio. The dealership says that it is not uncommon. They said that memory sucks a small amount of power, but over time it adds up, plus it has been hot this summer. I can jump in it and drive it every 7 days or so and no problems, but if I wait 10 or so my battery is weak. I did not tell them I have a replacement radio. I have my ipod set to not charge ipod also. Any suggestions? Common or should I check out something else?
Posted Aug 19, 2007 · 00:54 UTC#2
probably not (just) the avic. you could easily get a meter and run a current draw to locate the source. make sure not to have dome light on, or headlights/parking lights when running it for a current draw. you could then pull fuses one at a time to find where the largest draw is coming from. You can even get an acceptable draw rating from the directions with the meter yuou get.
I would bet theres probably something else doing it. I know my car use to do the same thing if left for 2 weeks without starting.. of course i had alot more to it then just a avic in it.
Posted Aug 19, 2007 · 01:36 UTC#3
if your gmos module is flaking out, you could be getting door chimes that you dont know about. enough of that will kill your battery
Posted Aug 19, 2007 · 04:26 UTC#4
When the battery does get low the door chime gets extremely loud. I then have to unhook the battery to get chimes to regular volume. Where should I start? Should i get a new gmos-04?
Posted Aug 19, 2007 · 10:59 UTC#5
would be a good place to start
Posted Aug 19, 2007 · 15:20 UTC#6
I had unit professionally installed. I don't know enough about this stuff to do it myself. Shouldn't the place that did the install be able to narrow down the problem? I do have a new gmos - 04 on the way from crutchfield.
Posted Aug 19, 2007 · 15:23 UTC#7
i actually work at chevy and this is a really common problem with all of there new cars, after they sit for about 2 weeks or so, they always need to be jumped haha
Posted Aug 19, 2007 · 15:30 UTC#8
you could disconnect it and do without the features of it temp for say 2 weeks? then be able to tell if its something running through that.... thats short of doing a current draw test.
