Anybody have a security sys they are really happy about and would recommend?
I assume most z2 owners have one.
I got an Audiovox one with auto start and two way paging that I love. Auto start is great for when it is hot or cold and by the time I get in my car the Nav has already booted up. And the two way paging just makes me feel that much safer. Fairly expensive instal depending on what car you have though.
This is what I have.
I have a clifford matrix something. No complaints and does all the things the previous post mentioned
i have a python 990
i have the code ca1670 which is really audiovox.
Most systems are really close to each other, if not made by the same company. Keep in mind the system is ONLY as good as its installed, it will never be better. The installer needs to adjust the shock sensor and other things to make sure its done properly, otherwise your usage will be a nightmare. You will not like a poorly installed/adjusted system nor will your neighbors. They all pretty much do the same things, few minor things different but they are dumbed down for the general public.
btw, the audiovox link one above doesnt work.
I have the Viper 2 way .. same as above... no problems...
alpine sea-8081. mack daddy of security, but out of production several years now. just saw one on ebay guy wanted 700, unit was brand new. now if i were a rich man...
Compustar 2-Way lcd !!!! Best dam Alarm-Starter I've ever installed!!! Amazing distance, easy of use, a lot of programable options.
