Saturn Sky VSS, where is it?
By Rit · Aug 21, 2007in Vehicle Specific Wiring💬 10 posts👁️ 2,206 views
Posted Aug 21, 2007 · 11:46 UTC#1
Where can I find the easiest place to get the VSS for a 2007 Saturn SKY with a manual transmission?
I went to the "rostra" website, but it didn't have the car listed.
The OEM radio had speed adjusted volume that worked. Could the VSS be that close to the radio already attached, or does the GMLAN thing have something to do with it?
Sorry if this is a double post, I didn't notice this section of the forum before.
Posted Aug 21, 2007 · 11:58 UTC#2
your car doesnt have a speed sense wire. the speed sensitive stock radio is through data, nothing you can use. some of those adapters for the gm vehicles will convert a speed pulse signal for you. if the one you need doesnt, your just gonna have to go the simple hybrid route. or get a speed pulse generator
Posted Aug 21, 2007 · 16:35 UTC#3
1) Could you tell me where I could find one of those "adapters" for my 2007 SKY that might generate the pulse that is needed?
2) What are the pro's and con's of the "simple hybrid" route?
3) Pro's and Con's on the Speed Pulse Generator? Installer mentioned something about the Speed Pulse Generator, but left me with the clear impression that it was NOT a good way to go. I don't remember why, but he didn't seemed impressed with it.
4) If it makes any difference to the above, I do have the bypass wired and installed in my unit.
Posted Aug 21, 2007 · 23:56 UTC#4
9 times out of 10 simple hybrid works fine. ive used the pulse generators on eclipe units and they've been fine. it didnt make much difference on my z1 though. try hybrid and see how it goes before you waste money on the generator. they arent cheap and kinda hard to find
Posted Aug 23, 2007 · 03:54 UTC#5
you can get the speed sense at one of the wheel speed sensors according to directechs. The sky I did didn't need a vss wire, so I didn't bother checkin it out for myself.
Posted Aug 23, 2007 · 12:48 UTC#6
when directechs says wheel speed sensor, it means you have to add one. otherwise there would be a wire color listed to use
Posted Aug 23, 2007 · 13:20 UTC#7
Thanks for that clarification. I would have been to the installer telling them to tap into the wheel speed sensor instead of adding one.
I was at another site and they are talking about:
2.4L w/Manual transmisson: VSS is mounted at the left rear of the transmission.
VSS High Signal is YE wire, terminated on Connector C3, Terminal 66 of the ECM
VSS Low Signal is PU wire, terminated on Connector C3, Terminal 67 of the ECM
C1 is BU with BK case
C2 is BK
C3 is GY with BK case
From all accounts the yellow wire seems to be the better one to hook up.
2.4L w/ Automatic Transmission: OSS is mounted at the right rear of the transmission.
OSS High Signal is YE wire, terminated on Terminal F1 of the TCM
OSS Low Signal is PU wire, terminated on Terminal F2 of the TCM
Does this make any sense, hook up to a yellow wire that connects to the ECM??? But he was referring to a Solstice, not a Sky. I have a 2007 2.4L SKY with the manual transmisson.
Posted Aug 23, 2007 · 14:16 UTC#8
the wires that they are referring to are probably data outputs which can not be read by the avic. both tech sources i use say to add a speed sensor.
Posted Aug 26, 2007 · 22:32 UTC#9
Keep in mind, you don't need the vss wire when using the avic units. I hardly ever use them and never have comebacks/complaints.
Posted Sep 01, 2007 · 14:52 UTC#10
MAKE YOUR LIFE EASIER!!! THINK smarter not harder like pearl95c said on the avics you dont need to use the vss wire!! The pioneers pick it up just dosnt have the exact location all the time and you will notice a lag and delay without the vss wire hooked up..... or a peice called CAN-VSS it automatically produces a VSS wire tach wire and much much more if the car dosnt have the vss wire just have to make sure its on a can bus system possibly might be a LAN data now all the new GMS are going that way
