Excessive Vibration & 0 Speed Pulse after Z2 Update.
By Scooter_Alberta · Aug 21, 2007in Hacks/Mods💬 2 posts👁️ 760 views
Posted Aug 21, 2007 · 19:12 UTC#1
Everything was working fine prior to update. I pulled the dash off after the update to perform the 2 wire ground. Put everything back together, and everything is unlocked (drove about 40+ miles), but when I go into the config screen it reads 0 for the speed pulse (when moving) and excessive vibration.
Did I unhook the VSS wire when I pulled my unit out or does it read 0 since it thinks the parking brake is installed? If everything is working ok so far should I just leave it until I start getting grief?
Posted Aug 22, 2007 · 00:30 UTC#2
the bypass has nothing to do with the speed sense. it should not read zero when moving. maybe you didnt screw the the dash kit in all the way and that is causing the vibration
