N4 Bypass
By kimb115 · Aug 21, 2007in Hacks/Mods💬 10 posts👁️ 2,779 views
Posted Aug 21, 2007 · 20:59 UTC#1
I am getting my N4's in stock in the next couple of days and I heard that the bypass might be the same as the N3. Does anyone have any info?
Posted Aug 21, 2007 · 21:58 UTC#2
no hard info yet, but it looks like all pioneer did was update the looks (finally) and go with direct ipod control from the d3 (audio and video). if this is true then, yes i would assume it has the same bypass. we have 2 on order, so as soon as i see them, i will try. but you know what happens when i assume....
Posted Aug 21, 2007 · 22:00 UTC#3
i make an ASS out of U and ME :shock:
Posted Aug 25, 2007 · 13:42 UTC#4
I do not think you can bypass this unit with the switch as before. It has a new bottom cover with no access hole for the switch. I also tried to use the paper clip method and it felt like there was no switch at all. Anyone else have a chance to look at one of these yet?
Posted Aug 28, 2007 · 20:00 UTC#5
yup no swich and the parking brake on off on trick dosen't work also only thing i can see is there are three empty pins on the rca plug
Posted Aug 28, 2007 · 20:37 UTC#6
Did you give those a try like they do on the Z1/2 and D3?
Posted Sep 04, 2007 · 18:23 UTC#7
so weve got nothing on this? my company isnt even ordering n4s yet but i still wanna know how to bypass em
Posted Sep 05, 2007 · 19:07 UTC#8
You ground one of the empty pins
Posted Sep 05, 2007 · 19:09 UTC#9
awesome wht u can confirm?
the pin on the power/speaker harness? or the RCA
Posted Sep 06, 2007 · 23:37 UTC#10
There is no empty pins on either harness...except between the rca ground pins...not a common place for adding the pin. Havent tried it but dont think it will work!
