rerock said:
I have a question. I wanted to know if anyone has figured out how to update the gracenote database. It doesnt read any of my new CDs. I cant get in touch with gracenote and pioneer is no help. Can someone tell when an update is coming or what I can do to fix this problem. It sucks typing in every name of every song when I record a cd.
The best way to handle these CDs is to duplicate them with a CDDB-aware CD recording application that supports CD-TEXT (I use Nero 6). When you burn the CD, just select the "burn CD-TEXT info" option (or whatever your app calls it), and it will store the titles on the CD-R/-RW disc. Then you can rip that into the Z1, and it will store all of the information except genre (which, personally, I haven't found much use for anyway). One small caveat with this is that the voice recognition in the Z1 will not recognize CD-TEXT discs automatically, but I explain how to manually fix that
in this thread.
This is a minor inconvenience, but it's an easy workaround; the CD ripping/recording software does most of the work, it beats entering the info manually on the Z1, and you also get mixed-case text instead of the upper-case only text that you're confined to when you enter the data directly on the Z1.
