I am going to install the D3 and was wondering where the VSS wire is located on my vehicle and also, what other out of the norm wire will I also have to hack into??
2006 Honda Accord wire diagram?????
Speed Sense blue/white ECM/PCM
Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the
passenger side. On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26.
On the 6 cylinder models it is in the gray connector A, pin 11.
Brake Wire white/black + brake pedal switch
Parking Brake green/orange - top of fuse box, large
white plug
Radio 12v white/green + radio harness
Radio Ground black - radio harness
Radio Ignition yellow/red + radio harness
Radio Illumination red/black + radio harness
Factory Amp Turn -on N/A
Power Antenna yellow/green + radio harness
LF Speaker +/- green/black - lt. green +, - radio harness
RF Speaker +/ - green/yel - gray or
gray/red
+, - radio harness
LR Speaker +/ - blue/white - blue/black +, - radio harness
Notes: On some models the LR speaker wires are blue - pink.
RR Speaker +/- pink - blue/yellow +, - radio harness
Notes: On some models the RR speaker wires are lt. green - purple.
hope this helps
thanks for the response. for the 4cyl model, it says its on the passenger side. what do i start taking apart and look for? also, where is the brake wire? do i even need to connect the brake wire?
there should be a plastic panel (triangular in shape) that you can remove that's connected to the center console on the passenger side. once you've removed that you will see the ecu (ecm, pcm whatever you call it). the wires will be there you might have to pull the carpet a little to get to the wires. as for the brake wire why don't you just do the bypass you will need to ground the brake wire. food for thought, if you are using the OEM kit for the replacement pocket underneath the factory radio, you will need to play with the mounting brackets as if you don't the radio will start out pretty far and you will not be able to use the pioneer dash trim (if not used you will have gaps on the sides, but an easy way to stash money and coins...could be used as a piggy bank!)
thanks for your post! it is greatly appreciated! it helped me out a lot! thanks again
I want to connect an amp and subs to a 06 accord with nav. Can I connect the LOC to the factory sub wires? What is their +/- color code?
