Patched Z2 Reset Annoyance (STOCK DRIVE only)
By rjedlich · Aug 22, 2007in Hacks/Mods💬 12 posts👁️ 2,007 views
Posted Aug 22, 2007 · 16:43 UTC#1
I posed this issue under the main Z2 patch thread, the response being this is normal system response to "excess vibration". Since I have applied the update I notice the system self reboot several times a week. This AM I finally confirmed it can happen with no vibration (vehicle motion) whatsoever. Approximately 3 minutes after car was started the system just rebooted before I started to drive.
I've heard from at least 1 other person that this seems to be a new issue since patch. Has anyone else noticed more frequent "self reboots" of their Z2 post patch? Perhaps this issue existed pre-patch as well, so if you experience frequent reboots please note if you are patched or not. It is plausible that the patch has introduced a glitch (memory leak, oversensitive vibration sensing, whatever) causing self reboots.
Would be nice to root this out. If there is a statistically small count of persons with this issue, I will open up and recheck all of my wiring - but I doubt it's my wiring.
Cheers
Posted Aug 22, 2007 · 17:59 UTC#2
I hope you are referring to using a stock drive, otherwise this poll is worthless.
Posted Aug 22, 2007 · 20:25 UTC#3
Yes, my unit is a February 2007 manufactured AVIC-Z2 with no physical modifications (including changing or unlocking of hard drive). Unit was installed by myself in June with no modifications (removal / wire changes) since installation or subsequent to patch. 2-wire bypass has been working flawlessly.
Posted Aug 22, 2007 · 20:36 UTC#4
Not a single reboot
Posted Aug 22, 2007 · 22:11 UTC#5
Yeah, I've never had a reboot on the stock drive with stock software.
Posted Aug 22, 2007 · 22:19 UTC#6
no reboots on the stock drive or the toshiba MK4032GAX
Posted Aug 22, 2007 · 22:20 UTC#7
Never had a reboot.
Posted Aug 22, 2007 · 23:13 UTC#8
never reboot with stock hard drive or Toshiba 4026GAX
Posted Aug 22, 2007 · 23:34 UTC#9
No reboot w/ stock drive.
Posted Aug 23, 2007 · 01:07 UTC#10
Never had a reboot ever. Just alot of hanging up due to obscenely hot weather.
Posted Aug 24, 2007 · 20:57 UTC#11
hmm, this is smelling like a wiring issue then. Either my ignition relay is on fritz or I have a connector poorly connected. Will investigate this weekend. Thanks to those who have responded thus far!
Cheers
Posted Aug 26, 2007 · 06:51 UTC#12
no reboots here
