HELP--VSS Location 03 F-250 6.0 Diesel
By CLVNGR · Aug 22, 2007in Vehicle Specific Wiring💬 3 posts👁️ 842 views
Posted Aug 22, 2007 · 21:51 UTC#1
I've been reading through this Forum (which is AWESOME by the way), and I just want to make sure that my VSS is located at PCM under the hood on the driver side firewall. Is this correct? I don't want to mess something up. I don't have an overhead system, if this helps. I've installed tons of stereos, but no GPS systems.
Also...since I'm using the stock speakers with a wire harness adapter, do I need to use the RCA connecter wires? The only reason I can see is to do the Yellow/Black wire Bypass, but if there's another reason why I need it...please tell me. I was just trying to avoid all the wires behind the deck if I didn't need them.
Again, thanks for any helpful info, and keep up the GREAT site...VERY helpful.
Posted Aug 23, 2007 · 00:04 UTC#2
Speed Sense gray/black instrument cluster or Also found at the radio on vehicles that have the in-dash CD changer.
you only need that plug for the bypass if your not using any amps
Posted Aug 23, 2007 · 05:14 UTC#3
Thanks a ton...
