Custom Background on D3 - "Pictures" Folder Not Fo
By M.J.H. · Aug 23, 2007in Custom Backgrounds💬 7 posts👁️ 2,853 views
Posted Aug 23, 2007 · 11:53 UTC#1
I just got an AVIC-D3 and I had about 15-20 pictures in a designated "Pictures" folder on my CD-RW data CD. I created a data CD with about 600 MB of MP3 songs and then 3MB from the folder "Pictures' and apparently when I went to "import from disc" and nothing was found. It said it was looking or /PICTURES and couldn't locate the folder. Maybe I should create another CD-RW disc with the same thing and maybe put "pictures" in all caps?
Any advice would be greatly appreciated! Thank you!
Posted Aug 23, 2007 · 12:57 UTC#2
I had that same problem when i created a cd-r with pics on it , MAKE SURE WHEN U NAME THE FOLDER ON UR CD-R ( PICTURES ) 8)
Posted Aug 23, 2007 · 14:21 UTC#3
No I did name the folder "Pictures" in my CD-R disc, along with another folder called "iPod Songs" that had a couple hundred MP3 files. That's what I'm confused about! I did use the folder name "Pictures" and it didn't find it, what am I doing wrong?
Posted Aug 23, 2007 · 14:24 UTC#4
IM NOT SURE BUT IT WORKED 4 ME
Posted Aug 23, 2007 · 16:14 UTC#5
Could be because your "filler data" is mp3s. Everyone here says specifically NOT TO USE MP3s for your filler data. I personally just made a CD with the pictures on it in a folder called "Pictures" and didn't add any other data. My disc reads fine.
Posted Aug 25, 2007 · 19:10 UTC#6
Okay, I made a CD with a folder named "PICTURES" and put 19 pictures in there. When I put it in the D3, it tells me that there is no directory on the disk with the name "PICTURES". What the heck is the problem here?
Posted Aug 26, 2007 · 02:40 UTC#7
I figured out what the problem was. I was creating my disk with Vista and it was putting a thumbs file in the pictures folder. Somehow this was messing things up. I created a disk with XP and it worked fine.
