Replaced N2 brian with N3 & not working
By 05hemiram · Aug 23, 2007in Hacks/Mods💬 4 posts👁️ 1,350 views
Posted Aug 23, 2007 · 20:49 UTC#1
I just replaced my N2 brain with a new N3 brain and now my system is not working right. the touch screen is not reacting and I can't change any of the settings....
PLEASE HELP!!!
Posted Aug 23, 2007 · 21:43 UTC#2
all i can guess is reset the system with the little button on the faceplate.
if that doesnt help then you have a problem with your unit or your data cable.
y did you replace the n2 brain?
Posted Aug 23, 2007 · 22:15 UTC#3
I read in an earlier post that I could upgrade my N2 by replacing the brain with an N3 brain.
It seems I can only toggle thru the features by using the source button and not the touch screen... I tried disconnecting the battery cable for over 10 mins to reboot the system... No luck...
Posted Dec 03, 2007 · 03:14 UTC#4
What was the problem? Did you fix it? Thanks.
Robert
