N1 Hide-away with N3 Screen
By slotour · Aug 23, 2007in Problems/Troubleshooting💬 1 posts👁️ 510 views
Posted Aug 23, 2007 · 23:06 UTC#1
After a failed attempt to solder the bypass on an orginal N1 screen. I gave up and re-installed the unit, failing to realize I ripped the ribbon cable. Sad Sad
Anyways, I decided to set the unit aside and look for a N3 Screen for an N1 hide-away. I found one on eBay that says that...
"NOTE: Unit seems to be fine during bench testing, but it has been reported that when installed in a vehicle the unit will constantly recalculate driving directions / navi malfunctions... selling AS-IS."
I would assume this means that the hide-away is having issues, nothing in the screen. I am wanting to know if I can use this screen with an N1 hide-away.
Thank You
