89 Chevy S10 VSS
By deeredude5510 · Aug 24, 2007in General💬 3 posts👁️ 734 views
Posted Aug 24, 2007 · 09:59 UTC#1
Trying to Install a Nav unit in a 89 s10 blazer 2wd. It has full guages and an auto trans. Anyone have any idea where I can find the VSS wire. Appreciate any help. Thanks.
Posted Aug 24, 2007 · 13:19 UTC#2
do you have factory cruise? if so you should find it there. green/white. it may also be behind the inst. cluster. if not you may have to go to the transmission speed pulse generator.
Posted Aug 24, 2007 · 16:55 UTC#3
yes it does have factory cruise. I will try that. Thank you for the help.
